that4wdwagon
- Messages
- 6
- Reaction score
- 1
I've got a Manco go kart with the Tecumseh Powersport 6.0 hp that I'm trying to get running as a Christmas present. I've rebuilt the carb twice and played around with it for the past week and I still can't get it to run perfect. When use the primer bulb to prime the engine I do it about 5-8 times and then I try to start it up, it will immediately hit and start up but then dies within a second. If I'm fast enough to hit the throttle before it dies then it'll stay running. All I have to do is hit the throttle real fast once and after that it'll stay running without me messing with the throttle. Once its running it kind of hunts/surges when idling and when it gets lower in the rpms it backfires. Every now and again it will just randomly die.. It may just be trash making it die but then why is it so hard to start it up? It also doesn't matter if the engines stone cold or if its been idling for 20 minutes. Its hard to start no matter what... Does anyone have any insight to what the problem could be? Like I said I'm kind of cutting it close considering theres only 4 days till Christmas, so the sooner I can get some advice, the better! Thanks in advance!!
-Dillon
-Dillon
