Have a tecumseh OHH60 power sport engine on a go kart trying to get going with no spark now. Originally the carburetor was trash and ordered a new one in meantime I tested my new toggle switch had power and had spark with a spark plug tester. I unbolted the shroud to clean the cobwebs inside there put back together.got carb installed last night now all sudden no spark.pulled shroud cover few times to check broke/loose wires and the green wire that runs to the shroud outside is reading good. Assuming somehow the ignition coil went bad? Or is it possible when I slid the shroud cover off to the side it threw timing off? Thanks for any info.
