Techumseh Carb Leaking Gas
tbmiller
Massillon, Ohio
Greetings,
I just purchased a used Craftsman Edger with a Techumseh engine, a H30 I believe. It has a Lauson carb, the type with the flat bowl. I found out this morning that it is leaking gas. Investigation found that it is coming out of the throat. Went to my local repair shop and they sold me a diaphragm repair kit, of which I installed the new diaphragm, needle, seat, spring and gasket. There were some other "O" rings left, but I could not see where they went, so I just replaced what I could see. Just reinstalled the carburetor and it is still leaking.
I just started it and it started right up. However after I shut it down, I could not restart, probably because there is gas leaking out of the throat. Not even a full choke would help. Guess I will have to let it settle down and try it again.
Can anyone help me out in solving this problem?
Thanks for any advice.
Ted
Atlanta, GA
I believe I've got the same engine on an implement. The bowl has to be turned just the right way in order to seal. Seems silly, but that's what I've found on mine.
tbmiller
Massillon, Ohio
Excuse me, I m confused. Here is the sequence that I replaced the parts. Diaphragm gasket, diaphragm (with round meal disk towards the inside), then the bowl cover. The bowl cover was put on the same orientation as when it was taken off. You say the bowl has to be turned just the right way. By that, do you mean the bowl cover?. And if so, how do I know the proper way?. And would that make any difference since I am not leaking from the bowl?
Now, I am not leaking any gas from the bowl itself. It is running out the throat. I am new to all this, so can someone help me in understanding where the gas goes once it leaves the tank? Maybe if I know how it travels, I can look in other places.
I truly appreciate all the help thus far.
Ted
Atlanta, GA
If gas is running out the "throat", then the float inside the bowl is not "floating". The bowl I am talking about is the thing that hangs under the carb held by a screw in the center. It holds a certain amount of gas, regulated by the float which is attached to a valve that lets the fuel flow according to how full the bowl is, effectively making the float "float". I too have thought I put the bowl on exactly like it came off, only to suffer with fuel running everywhere as you describe, because the rotation of the bowl was off by just a hair.
tbmiller
Massillon, Ohio
Ok, I understand. But I think we have two different bowls. My bowl is flat, and the cover is held on with 4 screws. I think the bowl you are referring to is round and deep. I replaced the needle, seat and gasket inside. That is really all that is in there. So, what is happening is the needle is allowing gas to fill the bowl constantly. If that is the case, then I am at a loss as to how to fix it. The needle moves freely, which should shut off the supply of gas.
Hope this makes sense.
Ted
tbmiller
Massillon, Ohio
Problem solved. I should have taken a picture while I had it off the engine. My bad!
In looking at a picture of what I think is yours, I noticed a small rubber gasket that fits in the brass holder, that the needle fits in. I did not see it when I took the other one out. Took it apart, added the seat, and it does not seem to be leaking. That would make sense, since it keeps the gas from entering into the bowl constantly.
I am attaching a link to a picture that I found on the Internet, that I think is your carb/bowl.
http://outdoorpowerinfo.com/repairs/tecumseh_carb_632334a.asp
Let me know if this is yours. Mine is totally different, with a flat bowl.
Another learning experience. Thanks everyone for the help.
Ted
tbmiller
Massillon, Ohio
Close. Is that the fuel line connection at the bottom of the bowl? Mine is on the other side of the view.
Just checked and it appears to have some fuel in the throat. But none was present in my drip dish underneath. So, will keep an eye on it the rest of the day, If anything, it has slowed down.
Will let you know the final outcome.
Ted
tbmiller
Massillon, Ohio
Problem solved, this time for good.
Talked to my local engine tech. Told him I had replaced the needle, and brass fitting that the needle and seat fit into. Still leaking. He mentioned that sometimes the threaded hole that the brass fitting screws into, becomes a little worn out and enlarged. So even though the needle may be stopping the fuel from entering the bowl, it is seeping around the brass fitting. Makes sense.
So to get around all of this I installed a petcock in the fuel line. Kinda figured from the beginning this might be the only way since parts and whole carbs are no longer available. Just close the petcock to shut it off.
Hopefully you can see pics I included. The pic on the right shows the flat bowl.
Anyways, thanks to everyone for all the help. Learned a lot on this project.
Ted
