Hi All,
I've read several threads on here relating to kart jerking, and now I'm one and still don't really understand what I should be looking for
. Picked up a Black Widow several weeks ago. I installed new Predator 212 w/ Stage 1 Kit and removed governor.
The drive/driven are in very good shape and almost look brand new, so I'm not sure what to think or how to solve this. It only jerks when you start to take off. Once past a few mph no more jerking and it runs great.
Notes - Drive/Driven spacing is exactly 7". I did not install a new belt, it is the same one I bought the kart with. Looks in pretty good shape and its oriented correctly. Pulleys look pretty much in line. Maybe 1 more washer and it will be perfectly aligned (I would guess it's within 1/8" of alignment......maybe that is the issue?), although there were no washers for spacing on it before.....but it had the LCT engine so maybe washers weren't needed. The belt is a "Pix-Asymmetra ASW 5959". Judging from the link, it looks like this is the correct one.
https://www.gokartsupply.com/5959belt.htm
I wish I could remember if BEFORE I put the Stage 1 kit on if it was jerking. I don't think it was....but I could be wrong. Not sure if that could affect?
Any insight would help. Does anything look out of the ordinary here? Hoping to get this solved before this weekend. Its the last issue I'm trying to wrap up
