True top dead center should be found with a degree wheel and a dial indicator on a stand. Put the degree wheel on the end of the crankshaft and make a adjustable pointer out of a wire coat hanger set it to zero. Put your dial indicator w/magnetic base on the deck surface. Zero the dial indicator on the top of the piston.
Now turn the crank until the needle on the dial indicator stops moving at it's highest reading. Record the number off the degree wheel. Now turn the crank in the opposite direction slowly until the needle just starts to move barely. Record the number off the degree wheel again. Subtract the highest number from the lowest record your answer divide it in half and there is true TDC.
Clear as the dog turds in my back yard.
