t.d.c questions
nixta
New zealand
Ok Had my head off and had a:idea2: and used a straight edge to set my piston at exactly at t.d.c would this be correct or am I going to:censored:something up royaly:rolleyes:
am I correct in assuming that guys
Half-breeder
"Edit" button removed
Not sure what you did w/ the straight edge... but if the piston is up ALL the way and can go NO higher... that is considered TDC position.
fowler
Bullsbrook West Aus
Tdc stands for top dead centre
Commonly mustaken as piston at the top
But u will observe u can rotate the crank +/- a few degrees each way without the piston cganging height
Top dead center means the piston is at the top of the stoke and the rod is in the middle of the bore
Most engines have a tdc mark
But if u wanna know tdc then u must have the side cover off
Just sorta eye ball it
Why do u wanna find tdc
nixta
New zealand
I used a straight edge cos I'm a perfectionist and don't like guesstimateing + my eyecromiter is crap to much arceye lmfao .... na just wanted to be sure it was exact tdc trying to solve my motor issues cheers guys
Half-breeder
Thats what I figured you did... however, there are some engines out there that the piston doesnt travel ALL the way up(+/- .010~.10), then again there are some engines(usually modded) where the piston may travel 'past' the cylinders lip(+/- .010~.10). So, Im just sayin 'that' form of attaining EXACT TDC probably isnt the all around best method.
fowler
Bullsbrook West Aus
Im still not getting how u used a straight edge
If its like half breeder is sugesting then that ll nlywork on that engine
Never seen one like it
Im saying u need to eyeball the rod in the middke of the bore
So the rod is straight up and down in the bore
Just because the piston is level with the block means bugger all
fowler
Bullsbrook West Aus
Yea for piston protrusion
To see wether u will have less compression or are you going to use the crank to remove the head
To get tdc
On engines that it matters for there will be a mark on the flywheel and the flywheel will be douled to the crank
For a lawn mower engine
It doesnt matter past eyeing it
True top dead center should be found with a degree wheel and a dial indicator on a stand. Put the degree wheel on the end of the crankshaft and make a adjustable pointer out of a wire coat hanger set it to zero. Put your dial indicator w/magnetic base on the deck surface. Zero the dial indicator on the top of the piston.
Now turn the crank until the needle on the dial indicator stops moving at it's highest reading. Record the number off the degree wheel. Now turn the crank in the opposite direction slowly until the needle just starts to move barely. Record the number off the degree wheel again. Subtract the highest number from the lowest record your answer divide it in half and there is true TDC.
Clear as the dog turds in my back yard. :eek:
:feedtroll:
On a small industrial engine, a degree or two will make very little difference to anything...
The way I find TDC is I place my fingers flat on the block with the tips hanging over into the bore; as the piston rises, you will feel when it reaches TDC; as fowler pointed out, there's a few degrees when the piston will not move, use a locater mark to indicate when it hits TDC & when it leaves, then split the difference...
This method is not 100% accurate but, as removing the side cover can throw out the crank position, it's pretty close...
firemanjim
Just kartin' around....
Houston Texas
:feedtroll:
Pretty much the exact words I was gonna use....... :2guns:
For a kart engine though, I'd just turn the crank to get highest,then past a little. Then back the opposite way SLOWLY until you hit the previous high number. For a kart engine, that's gonna be exact,enough....... :thumbsup: You can buy CHEAP dial indicators with stands for like $20.
