supercharger
Thepartsguy
Can I swear if I use
upside down text
backwards text
rainbow text
I know fakebook filters don’t catch anything in weird text formats.. I bet sights like DIYGK and OMB don’t catch it in there filters either.
65ShelbyClone
SoCal
I'm honestly impressed that the smog pump supercharger works well enough to keep breaking everything it's attached to.
Thepartsguy
Pictured
left: 5hp rod
right: 4hp rod
I’m working with a bottom barrel 163cc model 10 4hp engine from 1963 pictured on the right..
The rod pictured on the left is a top of the line I/c duel bearing 5hp engines stock rod.
Bottom barrel 1960’s aluminum bore no bearing 4hp engine has way thicker castings and better parts then a 1980’s top of the line I/C steel bore duel bearing 5hp..D0947CED-6AF6-4FF7-B70B-D539C3E1FAF7.jpeg
Thepartsguy
Going with a cog belt pulley setup like elseburghtuning.dk they had a slightly smaller pulley on theres but this will do. It took me the longest time to find out it was a gm smog pump with a cog pulley adapted onto it in place of the v-belt pulley. 23210564-25F4-4669-802D-559359112089.jpeg
