Thepartsguy
- Messages
- 1,575
- Reaction score
- 1,466
I know nothing of the pump unfortunately. I do know the pump got a full service along with 5 case holes and the pumps “pressure diverter“ valve plugged solid with jb weld.Do you know the displacement of the pump?
How many CC per revolution?
And the pulley sizes?
And the displacement of the engine?
Did you try to calculate the amount of boost to expect? I have an idea of how to do the math, but not 100% sure it is correct.
On YouTube a non touched out of the box 1970’s pump put out 3psi on the persons gauge. I figured if it pushes 3psi before the diverter opens along with 5 open case holes I would get 5-7psi with all that plugged and a back case gasket. I got way more.
5 3/4 driven 4 1/2 driver.. My plans are to have fun and really push it. I have a super high compression head. I thought kick the timing back and I have a 4 3/4 pulley for the pump to make it 1to1 ratio. It keeps wrecking headgaskets.
It’s a 163cc briggs 4hp with a flywheel. No other work done. Billet rods do not fit 4hp model 10’s
