JokersAce69
I was talking about the idle speed screw. Not the screw on top where the throttle cable runs through and you tighten down The cable.
That spring between the throttle arm and governor arm looks a bit messed up... or maybe not even stock? And yes, that's the one that would be giving you problems like you're having.
Double check to make sure your throttle arm (the one your pedal cable connects to) is closing/returning all the way. Then make sure you can't loosen and rotate your governor arm towards the closed position at all.
Otherwise I'd pop that spring off, measure it, and stretch it out just a bit (Maybe 1/16" at a time?).
When the engine is off you generally want the throttle to hang open, but as soon as you start it then it should close up to your idle setting pretty much immediately. If that spring has a different rate from the stock spring your engine may be governed at the wrong speed... verifying it in some way would be wise.
