Subaru EX 21 engine idle
JokersAce69
Mesa, Az
I was talking about the idle speed screw. Not the screw on top where the throttle cable runs through and you tighten down The cable.
JokersAce69
Mesa, Az
KartFab
lol dont throw in the towel yet:
here is what you need to do; pick up the towel and use it to wipe your tears so you can read the print without it being fuzzy.
http://www.subarupower.com/media/manuals/129036362809063750.pdf
turn to page 42 (listed as 45 on my browser) and just figure it out. Your springs look a little messed up too so you may just need to replace them. There are parts manuals that you can look up and find what to buy.
This service manual will help you more than anything if you just spend the time reading it.
JokersAce69
Mesa, Az
Okay, Okay, I Won't give up yet.. lol
Agreed completely on the springs looking way out of whack. they all have good tension and response. As for the spring on the governor assembly it does look a little stressed out but when the engine is ..running.. It looks like it plays no difference. I could be wrong considering i'm trying to get some help because i can't figure this out on my own.
I went ahead and took the carb out completely and cleaned it.
Also adjusted the governor arm as per that diagram you gave me.
- The Idle screw position i have it in when i physically hold it down has the engine at perfect idle.
I didn't get a chance to start it up and see where it's at being as it's late and i don't want to be "That neighbor". I'm really leaning on the air/fuel mixture needle as the culprit. It says "lightly seated and back out 1 full turn. My Kung fu grip has no idea what that could mean.
Badot
That spring between the throttle arm and governor arm looks a bit messed up... or maybe not even stock? And yes, that's the one that would be giving you problems like you're having.
Double check to make sure your throttle arm (the one your pedal cable connects to) is closing/returning all the way. Then make sure you can't loosen and rotate your governor arm towards the closed position at all.
Otherwise I'd pop that spring off, measure it, and stretch it out just a bit (Maybe 1/16" at a time?).
When the engine is off you generally want the throttle to hang open, but as soon as you start it then it should close up to your idle setting pretty much immediately. If that spring has a different rate from the stock spring your engine may be governed at the wrong speed... verifying it in some way would be wise.
JokersAce69
Mesa, Az
Spring between? Which picture are you referring to? Yes the throttle arm is closing/returning all the way and the governor arm I just set last night to factory. /clockwise.
JokersAce69
Mesa, Az
Update: I loosened up the return spring about 2 coils and whatta ya know.... The engine idles. It still barely wants to take off when I start it but I drove it around and all is good. I'm just going to buy all new springs and call it a day. Also need new back tires and a 5959 drive belt. The brakes are pretty shot.. I'll tear that down later and adjust them to see if there is in life left in them.
