Subaru 7HP engine help
JokersAce69
Mesa, Az
Tried everything engine doesn't want to idle low. Engages the TC and kart want's to take off.
It seems the idle screw just "bounces" off the carb body once the engine has started and won't stay fully depressed. What could be the issue?
(Screw seated against the carb body)
(screw away from the carb)
Lemme see if I have this-
If you start the engine, and HOLD the butterfly closed, the engine will idle, but if you let go, it takes off, yes?
qtband
St. Louis, MO
Sounds like you're missing a return spring. Try to find the engine specs & pic on Subaru'a web site and look for a missing spring on the carb somewhere.
That's one possibility. Also, the governor could be out of adjustment. Could also be a loose carb, bad carb-to-head gasket. It could also be that your throttle cable is too tight.
JokersAce69
Mesa, Az
All the springs are there, i think the governor is not aligned right.
It comes in contact with the body but starts to bounce off maybe a few mm then touches, then bounces etc etc.... I'll check the gasket next. But yes if i hold it, it works fine.
JokersAce69
Mesa, Az
I cleaned it out really good, sprayed it with carb cleaner, stuck fishing line through all the tiny holes and used an air compressor afterwards.
JokersAce69
Mesa, Az
The engine is about 8 years old always ran fine up until it got stored away. Like i said yesterday i had it running to the point where it wouldn't take off but then i had to tighten up the chain because it had bad slop. But i think i didn't tighten down the governor lever enough so it threw me back at square one. The chain has 3/8 flex and the belt is nice and loose but not too loose. The only bad gasket is the Intake air assembly gasket. The insulator gasket and carb gasket are perfectly fine.
By the way this is the carb http://outdoorpowerinfo.com/repairs/subaru_robin_mikuni_27x-623xx-xx_carb.asp
If it ran beautifully until stored, and all you did was service the carb, then it really looks like that's where the fault lies. Now, what do you mean by not tightening down the governor lever? What (in relation to the governor) did you alter?
JokersAce69
Mesa, Az
Update: I have it running better. I adjusted the governor arm. Still a slight rpm jump every few seconds (idle screw bouncing) it doesn't want to take off as much as it did. I can stop the wheels with my foot but after holding it for maybe 10 seconds the belt gets grabbed and there is a good amount of resistence.
Stoopid question, but why did you adjust the governor arm in the first place? Should not have been necessary for a carb cleaning- although I have not messed with a Subie yet.
JokersAce69
Mesa, Az
There is a bolt and nut on the lever that holds it to the governor rod, the bolt was completely stripped and the assembly was loose. So i replaced the nut. But the settings were already out of whack so i had to deal with going back to factory settings. I did not intentionally mess with the settings if that's what you're asking. lol
Now as far as the carb settings it just seems to be idling a tad too high. Would this be curable with adjusting the mixture needle? I also had one more quick question. Nevermind i got the kill switch working!
Start by getting the governor bang on- do you have a manual? Usually, the technique resembles this-
Loosen the nut/bolt that holds the arm to the shaft. Manually turn the arm as far towards WOT as it will go, and hold. Now, manually turn the shaft in the same direction as far as it goes, and hold. Now, tighten the bolt.
Once all that is good, you can start adjusting the carb.
(Please note, the above method is more-or-less true for the vast majority of the engines I have messed with- I have NOT examined a Subaru- but the principle should be the same.)
JokersAce69
Mesa, Az
That is what i did, i have it all good now, i just took it out and now it runs as close to perfect as it's gonna get. I forgot how much power this little engine had. A few ugly stares from people and now i'm back to finishing my kill switch and headlight installation. Thanks a bunch!
JokersAce69
Mesa, Az
Me too, 40 hours into complete kart rebuild only for the engine to be a p.i.t.a. Was really putting me in a bad mood. *unloads 12g* :sifone:
