Start by getting the governor bang on- do you have a manual? Usually, the technique resembles this-
Loosen the nut/bolt that holds the arm to the shaft. Manually turn the arm as far towards WOT as it will go, and hold. Now, manually turn the shaft in the same direction as far as it goes, and hold. Now, tighten the bolt.
Once all that is good, you can start adjusting the carb.
(Please note, the above method is more-or-less true for the vast majority of the engines I have messed with- I have NOT examined a Subaru- but the principle should be the same.)
