Stuck clutch...
Budget GoKart
Aka a kenbar
roachdale, indiana
So i dont have a picture but i got a naskart recently and it came with a racing clutch and sprocket and a 6hp tucumseh how do i get the clutch off it has the springy things pokeing out the back ill look for a picture someone help please i dont wanna break it
JTSpeedDemon
2019 Build Off Winner!
Texas
If you have a clutch similar to that, then that's a DISC clutch. Usually used in racing. FYI they are VERY EXPENSIVE. The cheapest brand new one I've found is about $200! Then again, in your video you speculated there was once a racing engine on the NasKart, so it would make sense if there is a disc clutch on there. Show us some pics!
There should be just one bolt holding the clutch on the shaft...
That bolt might also have a grease fitting as these are a needle/roller bearing clutch, that requires grease not oil for lubrication...
But post pics to show what you have..
Off hand... Thats a Horstman MDC racing Clutch...
You have that on backwards. That is an inboard running only type... That might be why it stuck....
Make sure the center bolt is out...get some wooden broom handles or the like...
Start prying carefully on both sides...use some penitrating lubricant on the shaft...
Work at it carfully...
Here in Canada... They are hundreds of dollars.. Expensive...
JTSpeedDemon
Texas
If it won't budge right after you hit it with Blaster, let it soak for a few days, and keep hitting it with Blaster every few hours.
Tpdingo
Bellmore, NY
The worth of the clutch is more than the motor a few times over so I wouldn't even hesitate to drill out the crank if it came to it.
JTSpeedDemon
Texas
OK:
THAT TECUMSEH DESERVES TO DIE!!!!!
I think I've gotten my point across.
Trevor, go ahead and just see how long you can make that Tecumseh last.
We lazy guys will just watch the show. :popcorn:
---------- Post added at 01:54 PM ---------- Previous post was at 01:53 PM ----------
And FYI Trevor, you might wanna change your avatar, because I just realized your avatar is the Budget Go Kart, which you traded.
---------- Post added at 01:55 PM ---------- Previous post was at 01:54 PM ----------
So your avatar is someone else's go kart! :lolgoku:
