Muffler reinstalled. Stronger than the original design. Has a nice race like sound and you can definately hear the cam better. Havnt ridden it yet to test but it's much louder than before but not as obnoxious as an open pipe.
And I have discovered it also shoots fire out of the pipe now.
Why so much work to get the shavings out of the exhaust?
The muffler sits higher than the exhaust port. I didn't want any chance of the shavings finding their way into the head. Plus I was going to rivet it together anyway to keep it from becoming loose and rattling again. This is my 3rd muffler. They can't handle this motor to well.
I just got done checking my valve to piston clearance and installed a 0.010 head gasket, replacing the original 0.045 gasket. That project went very well and the motor runs a little stronger than before.
I had a problem with my driven unit flying apart a couple months ago. I replaced that. Then I discovered my driver spring was stretched out way to far and the weights were very worn.
New one is in.
New high speed run after mods and thinner head gasket. Opened baffle muffler.
https://youtu.be/0E6x2Ic29bw
