Strange engine issue...
asdfasdf128
NJ
well I tried to find the low oil sensor wire, but there was nothing on the engine. The only wires that were there were essentially those that supplied power to the sparkplug, controlled the kill switch, and a grounding wire. Guess I'll just have to take it to my local lawnmower shop & let them figure it out since its no longer starting at all.
1992suburban
I wanna go FAST!!
Sanford, NC
is it making spark??
you never said. try unhooking the kill switch if NO SPARK . leave the circuit open
if its getting spark then its Fuel related. float out of adjustment? very little fuel in thebowl
Kaptain Krunch
Pro Junk Collector
vermont
unscrew the sparkplug and rest it on top of the block with the plug wire still connected, pull the engine over a few times and see if the plug produces spark.
asdfasdf128
NJ
Well guys, I checked for spark, and literally got shocked, but I was glad it sparked. I undid the kill switch, and the kart is restarting normally again. I'm not quite sure why the kill switch would cause those issues since the wires were not detached or loose, but whatever, it works now :) Thanks again for everyone's help!
freakboy
the names 'mater
hick town
yeah sometimes its a good idea to hold the plug wire with plyers lol if your a better ground then the engine it likes to shock you lol
anderkart
Surprise Arizona USA
Kill switches can sometimes malfunction and engage themselves from debris or moisture getting inside or just plain being poorly designed and manufactured. Yours is the first I ever hear of that was effected by the angle of the kart but I can see how that could happen. You should probably install a new kill switch, If your throttle ever stuck wide open a functioning kill switch could end up saving your life...
