hf 6.5 is said to do 3600 bone stock. i've yanked the governor, swapped heads, straight pipe, removed paper element from air filter, stiffer springs, longer rockers, flat bottom valves. i think that is all i have done. 50 wt oil, mid grade fuel. 10/62 on sprockets. i top out according to my schwinn 12 function comp at 21mph ~=3700rpm. plenty of umph, any ideas? if this is my true revs then i will venture to do some porting, adjustable jet, trim fins etc.
