robbie
To answer the original question, the downside to flux core welders is the price of the wire. It costs about $10 per pound, which is a lot more than mig wire.
The upside is that it's about as easy as it gets. It took me just a little while to learn to make a good weld in lightweight steel that you would use in a go kart or mini bike frame. I had to get over my stick welder habits of stirring the little pool to get it to flow on both sides. With the Harbor Freight flux core, you set up a tight joint and just run along it like a zipper, assuming that you have your controls set correctly. And it comes with a book telling you how to do that. I set it where they said and I move the controls only when I'm welding a thicker piece.
