Steering Question
noley99
I asked this in my post in the pic section but this is the more appropriate place.
The kart I'm building is a little stiff in the steering dept. Would a larger steering wheel help or should I just install bearings on the steering rod?
noley99
I'll have to say that I have no idea. It's stock from the murray frame with the exception I've converted it to a single seat vs. a 2 seater.
Buick455
got any pictures of it?
Florida
If its the blue kart that you talking about...
Didn't you just have it powder coated or painted? This could be your problem because I know paint and powder coat have a tendency to make big holes smaller, lol.
If that isn't the case I would disconnect the tierods and see where its binding, spindles or shaft (could even be the rod ends, but i doubt it). Then try greasing the steering shaft or spindles... Good luck :cheers2:
noley99
Yeah, that's the one.
I was extremely careful when i painted it and I have also greased the the shaft and the tie rod ends. I'm sort of stumped.
theo
From what I see in your pics, is that your bell crank on the steering shaft is to long. The shorter it is the more the steering wheel will turn, which is the same as gearing it down. Can you give a close up of the spindles and the bellcrank?
theo
noley99
Here you go. See if that helps.
theo
Try mounting your tie rod ends 2" up from the center of the steering shaft. You should have some ackerman and some KPI in the steering geometry, these will all help in your steering.
theo
Buick455
Florida
That’s all the stock Murray kart parts right? I can’t see it not having good or at least decent steering geometry. You didn’t make the frame longer or wider. Just a bigger engine, batt box, and pedal placement right? They are the stock front wheels too aren’t they? It always live axel right?
Do the wheels turn ok with the front end off the ground?
Did both spindles turn freely without the tie rods connected?
Did the steering wheel turn freely without the tie rods connected?
Theo’s right that the bell crank/pitman arm looks a little long, but to me it also looks like the spindle arms aren’t at the right angle to the stub or long enough for that bell crank/pitman arm. This is all coming from the pictures so it’s hard to tell.
Could be too much positive caster. Does she drive strait as an arrow without any effort, and when you do turn it straiten back out easy?
Honestly, I feel like I’m grasping at straws here, but I really don’t think a Murray kart would have this issue unless something was damaged or changed. I’m very confused :confused:
noley99
1)Do the wheels turn ok with the front end off the ground?
2)Did both spindles turn freely without the tie rods connected?
3)Did the steering wheel turn freely without the tie rods connected?
I'll do my best to answer all questions.
The steering parts are not stock Murray parts. They were all ordered off of the net. I have converted it from 2 seater to a single seater.
1. Yes
2. Yes
3. Yes
Do you think if I lengthen the spindle arms or shortened the bell crank that might help? I will try anything that might help although shortening the bell crank might be the last thing I do.
theo
Take a piece of 1"x1/4x3" and drill 2 holes 1 1/2 to 2" apart in this piece. Clamp it to the bell crank and now you can adjust up or down. Now you can see where can get your full throw at the spindles and on the steering shaft. You want as much turn on the steering wheel before it over locks. Also lengthen the tie rods so that they cross over on the bell crank, one on the back side and one on the front, this will give you ackerman.
Buick455
Florida
Ok, well with all that answered it’s definitely a geometry issue. I don’t suppose you have the old spindles anymore? If you do, just look at them compared to the new ones. My stock Azusa spindles needed the steering arms lengthened. They were much too short. I would give Theo’s' idea a shot, if that doesn’t help try adding some reach to those spindle arms.
Do you remember the model name of the frame? Maybe someone will pull some measurements for you if they have them on hand.
noley99
I am going to try Theo's spindle trick.
As far as the frame, it was laying in a scrap pile with no spindles, no floor pan, nothing basocally but the frame and the steering rod.
theo
Another thing you can do is move your tires in closer to the spindle arm. You want the tires closer to the spindle pivot bolt.
theo
Buick455
Florida
Well I did some hunting and I think the arms are your problem.. If you look closely at these pictures of murrays I found on the net, it looks like they have a very upwards angle for the steering arms. I know the Azusa spindles are nothing like this (I have them on mine too, but modded to work). Hope this works out for you :cheers2:
theo
Buick, the angle of the arm won't make any difference, what counts is the ratio between the shaft bellcrank and the length of the arm at the spindle.
theo
theo
Here is a steering set up I built with AZUSA spindles and it worked great. Note the length of the bell crank.
theo
[/IMG]
