Staff Murderator
- Messages
- 9,433
- Reaction score
- 4,362
Steering axis inclination. Hmm...
Ran across a rudimentary site on caster...http://www.formula1-dictionary.net/castor_angle.html
I think this portion is the most telling:
"Improper adjustment will result in steering inputs required both into and out of a corner, resulting in a car which is difficult to keep on a straight line. Too much caster (positive caster) and the front of the car will understeer more, too little (negative caster) and you will get oversteer handling characteristics. A large positive camber setting (wheel facing forward of axis) is good for high speed stability but can make it more difficult for turning the steering, excessive amounts will increase tire wear.
Excessive caster angle will make the steering heavier and less responsive, although, in off-road racing, large caster angles are used to improve camber gain in cornering."
