Steering is very touchy
Staff Murderator
Steering axis inclination. Hmm...
Ran across a rudimentary site on caster...http://www.formula1-dictionary.net/castor_angle.html
I think this portion is the most telling:
"Improper adjustment will result in steering inputs required both into and out of a corner, resulting in a car which is difficult to keep on a straight line. Too much caster (positive caster) and the front of the car will understeer more, too little (negative caster) and you will get oversteer handling characteristics. A large positive camber setting (wheel facing forward of axis) is good for high speed stability but can make it more difficult for turning the steering, excessive amounts will increase tire wear.
Excessive caster angle will make the steering heavier and less responsive, although, in off-road racing, large caster angles are used to improve camber gain in cornering."
Flyinhillbilly
The great cornholio
North West Arkansas
Steering axis inclination is the angle of a straight line drawn between the top and bottom pivot points of the front steering knuckles. The camber is compensated for by the angle of the spindle in relation to the kingpin. It basically has the same effect as caster so you don't have to lay your tires over so far while turning and therefor maintains a better contact patch and more available traction for steering.
Everett45
Idaho
To everybody that gave me input: I apologize for not updating you after my project was completed. I guess I was just too absorbed in it all to go back to the forum. Anyways, it turned out great IMO. I have not rode it yet, but I can tell I could've used some more positive caster. From what I can tell from turning the wheel while stationary, it is going to turn like a dream. The old steering used to bind up and didn't go as far in one direction as the other. Here's some pics:
