utahoutdoors
New to go-kart building. Something I have wanted to do since I was a kid.....
Will DS and I have talked about it for off and on. So we decided it was time. I have done a ton of go-kart web surfing and have collected a good measure of links of different ideas and sites.
So I made the decision to go with a two seater with double
wishbone front suspension using "A" style in the front.
Then using a suspension in the rear to make suspension on the rear area of the motor with the live 1" axle.
Using a 1" X .120 square tubing. Not ever welded a day in my
life until a few weeks ago, it become a good learning experience. While some are pretty bad I am getting better every weld.
I have gone with 1" live axle in the rear using a 420CC and using a TC series 40. With the front using 3/4 spindles using the AZ2298 3/4 spindle with tapered bearing seats.
With another tread conversion I still making decision on the
tire sizes. Using 8" steel ATV RIM for front and rear.
While going with a 8" X 7" wide steel ATV style RIM in the rear and using 18X9.50-8 or 18X8.50-8 in the rear. But the front I
really wish to go with a narrow wheel because of turning off
road on dirt and sand. As 99.9% of my travel will be on BLM dirt, rocky and sandy roads. So going with the front 8 X 5 7/8 RIM. It uses a 16X6.50-8 tire. Unfortunately no 18" tire for this narrow RIM. So is the 6.50 tire narrow enough or should one consider going smaller width?
2 pics on the start of the build.... one with just the 2 seat area. Followed by a start on the double wishbone (far from complete in this stage. Then the rear motor area.
