sqaure tubing
r97
Measure twice cut once
Massachusetts, USA
?????? are you asking if thats a good wall thicknes for square tubing? if you are what are you using this tubing for?
The_Machine
GA/AL
This here is the species of duncecicus maximus, native to these parts. I'd use 1/16 on a coffee table.
modelengineer
Lord of the noise
Sydney, Australia
You're better off with a larger diameter with 1/16" thickness, like 2"x2"x1/16".
Going up in diameter is much stronger/stiffer than going up in wall thickness.
Also, with a decent frame design (not a ladder) 1"x1"x1/16" will be fine.
r97
Massachusetts, USA
depending on how much metal your useing and how strong you want it to be it could be perfect, or it could be complete over kill and lots of extra weight. sooooo, what kind of kart are you building?
homeown
Canada, Ontario ( near barrie)
Ok, So with all this extra weight, Is this going to slow down my kart alot?
If I were to build the frame without sup, and had my 6.5hp clone, and a TC>?
Tires may have little tread, But I will be looking for smallest tires, that I can get and will not cost alot but be safe.
So with what I kind of gave to you for my info, what may I get for speed?
fowler
Bullsbrook West Aus
speed is all a matter of gearing
u want ultimate speed u get rubish acceloration
u want acceloration u get bad speed
may gear it for 40 KPH
r97
Massachusetts, USA
you should probaim for 15 to 30 mph and decent off road ability. if you want i can calculate a rateo for you if you give me your tire dia. oh and are the plans you got caling for 2"x2" tube if not you may have to change things around a bit
homeown
No there not calling for that, They call for 1 1/8 x 120walls
So I think I am going to wait till I find mild steel sqaure tubing around that size. I think I seen some 1x1x100wall and it seem to be pretty strong?
