Sprocket ?'s Birel shift kart,yz125
anderkart
Surprise Arizona USA
You could use a 1/4" fitting similar to this pic,
drill a slightly undersized hole in your boot so it'll fit realty tight,
then put a little RTV black gasket maker sealant on the fitting before you press it in.
ia-turtleboy
NW Iowa USA
http://i518.photobucket.com/albums/u344/ia-turtleboy/IMG_20140330_200358_zpsagmeavgt.jpg
Here's my fuel pump. I'm confused on running all the lines from thus to to the carb to the tank.
http://i518.photobucket.com/albums/u344/ia-turtleboy/IMG_20140330_200535_zpseivitk7d.jpg
here's my carb I'm not sure about all the outlets on it,I know the main side brass fitting is the fuel inline stem, but what is the little fitting coming from the float bowl.also there is a outlet fitting on each side of nthe carb(next to the chicken knob).any help¿
anderkart
The arrows indicate fuel flow through your pulse pump:
So the In-arrow fitting connects to your fuel tank.
Then those 2 Out-arrows are indicating the pumps dual outlets, you can cap/plug-off either outlet and then connect the other outlet to your carbs fuel inlet.
Those extra fittings on your carb are all vents, you simply need to connect 8" to 12: long hoses to each fitting, and then run/secure all those hoses down to the lower-back side of the engine, so they can vent the carb and carry fuel away from a source of ignition (hot engine/chamber/spark) for fire prevention reasons in case the carburetor ever developed a severe flooding problem.
Joe-405
Enjoying New Projects
U.S.A.
First of all sorry about the double post...........
All 3 of those are for a vent tube. Mine dont have anything on it either. I would put them on it tho. They keep debris and crap out with hose on it. Yours is similar to pic....................
I have the same fuel pump. You have 1 in, 1 vacuum, and 2 outs. The separate one on the bottom is the vacuum that makes it work. it goes in the intake somewhere between the cylinder and carburetor. The 2 outs you can either block one or run a y and use both into one.
I made a diagram for the pump, The 1 underneath not shown is the vacuum source from the intake somewhere...................
Finally the 3rd pic is where mine is for the fitting for the vacuum to the pump. You can remove the rubber boot slide the reed cage out and plug the hole with a towel and drill and tap the side of it somewhere,
ia-turtleboy
NW Iowa USA
OK thanks guys,so a few more for yall d.o I run the extra outlet to the tank for a return line? Or t of it the line going from the pump to the carb? And what fluids do i need for this yz125 2 stroke.What fuel /oil mix ratio.im at a loss for what fluids need to be put in this motor.gearcase and all.do i use plain ole regular coolant?I'm so close to finally being able to run this machine.I'm pumped but don't wanna mess anything up.
Joe-405
U.S.A.
regular green 50/50 coolant mix with water.
i use 10/40 oil in mine from a motorcycle parts place. I would check cause they are different on different engines.
and you can t or block the port off. mine was either way. no change.
DO NOT use it as a return it made mine run lean.
32 to 1 is a good starting point for fuel and oil mix.
ia-turtleboy
NW Iowa USA
Just got this thing ready to go and my clutch doesn't work.of course its my 99 yz125 engine on it. When I pull the clutch handle in, the axel still turns the motor instead of spinning freely.nowni know the cables good and have adjusted it.today I got a new gasket and pulled the clutch cover off today and am stumped. Is this piece, ( I assume is the push rod) supposed to spin freely?also is been dry for a year or too so maybe they need to soak in the gear oil required in the tranny?I'll post a small video. Any ideas? Thanks
brandonhuston
huntsville alabama
i just bought a yz85 for my cart that is alott like yours. it will be in the mail tommorow and that is when ill start. so i might have alott of questions if you dont mind
ia-turtleboy
NW Iowa USA
can't wait!
Looking forward to seeing all your progress,everybody on here always has a good 2¢ to throw ya,great help and info here:thumbsup:
brandonhuston
huntsville alabama
thanks! i just opened up the package with my new yz85 engine! im kindof where you were when you started. i have everything i need right now (i think) except a #428 chain, the axel sprocket to match the motor, the motor mount, and then the shifter and clutch lever. do you have any idea if the dimensions for the motor mount is the same for a yz85 and a yz80? or even a yz125? i figured if i could get this engine mounted, it would be easier to figure what exactly i need.
brandonhuston
huntsville alabama
also i am confused on how to measure the frame for the motor mount. the mounts are 30/32mm by 90/92mm. i measured and i got 29mm by 74mm. so i know i need a 30mm. but i am unsure about the second number. ive read to measure the distance between the 2 bars from the middle of one to another. but it isnt coming out right :( i need a mount asap. help!
