4.top view of engine mount/seat mount area
Looks like the forward mounting bar is missing, there should be two
5.picture of my pedsals cause im not quite understanding the welded plate on the brake side.
That's a mounting plate for an hydraulic master cylinder. The rod then attaches to the master linkage
looks like they had the disc brake on the right side and a sprocket on the left. but it did not come with a sprocket on it, so im not sure.
It makes no sense why they would do that as the brake pedal is on the left & the engine is on the right. The standard config is to have the sprocket on the right & the brake disc on the left.
So, I have good news & bad news (or maybe just all bad, depends how you look at it): If you put the sprocket on the right, it won't slide far enough in to be inline with the clutch sprocket once you mount an engine so, it looks like you're building a jackshaft anyway
Sweeeet lookin' frame BTW
Very retro
Oh, as for removing the axle: Have a look around the bearings & that BA collar (behind the brake disc) for grub screws (set screws)
