sprocket ratio question
EBACH
va
that'd be pushing it for sure. unless i go to a taller tire. whats normal size for track karts?
EBACH
va
also, if anyone could tell me how to get that rear axle out i would GREATLY appreciate it. i only saw one set screw near the right side bearing. no i do not know the manufacture of this kart frame.
EBACH
va
Jackshaft here I come..........
new to all this. there's probably a thread explainning this, but what is a jackshaft? is that what my rear axle is? not very often do i see an enclosed axle, usually i see them with just bearing on each side and you can see the whole axle. mine you can only see about 10in on each side, the rest is in that stupid housing.
No, a jackshaft is a system of using intermediate sprockets to achieve compound gear reduction. With a jackshaft you can use smaller sprockets, and therefor not have any ground clearance hassles.
Here is a pic of one on my minibike.
Can you post more pics of the frame? I have a few questions:
1. Was there a sprocket on it when you got it? If so, where is/was it?
2. Where is the engine mount? I can't see it in your pic
Also include a pic of the axle & housing
EBACH
va
from top to bottom:
1.left side rear axle
2.right side rear axle
3.side view
4.top view of engine mount/seat mount area
5.picture of my pedsals cause im not quite understanding the welded plate on the brake side.
6.then just a picture of the frame when i got it with all four tires on.
looks like they had the disc brake on the right side and a sprocket on the left. but it did not come with a sprocket on it, so im not sure.
let me know if you need anymore pics. thank you for all the help/info/advice!
Looks like the forward mounting bar is missing, there should be two
That's a mounting plate for an hydraulic master cylinder. The rod then attaches to the master linkage
It makes no sense why they would do that as the brake pedal is on the left & the engine is on the right. The standard config is to have the sprocket on the right & the brake disc on the left.
So, I have good news & bad news (or maybe just all bad, depends how you look at it): If you put the sprocket on the right, it won't slide far enough in to be inline with the clutch sprocket once you mount an engine so, it looks like you're building a jackshaft anyway :D
Sweeeet lookin' frame BTW :thumbsup: Very retro
Oh, as for removing the axle: Have a look around the bearings & that BA collar (behind the brake disc) for grub screws (set screws)
EBACH
va
yea i thought something was missing for the motor mounts.
hydraulic brakes on a go kart? wow. ha. how much $$ do those systems run? easy to install/maintain?
i didn't think the disc belonged over there. there is a mounting plate for some sort of brake caliber it looks like. is there any way possible i could keep the disc brakes on the right side?? if i turn my motor so the drive sprocket is on the right, then my exhaust will be facing the wrong way. really wish the axle didn't have that tubing around it, i'd have more options.
i only saw the one set screw on the right side, but i'll clean them off better tomorrow and have another look.
and thanks! this is my FIRST small engine/go kart project and i'm 30. HA! should be interesting.
Hydraulic brakes on karts are very common. Most of us just buy used hydraulic brakes off old scrapped motorbikes. Their brakes are great (and relatively cheap second hand) for karts. They are relatively easy to install with a little fabrication work.
Just remember if you turn the motor around that the engine will then be pushing you backwards and not forwards. Your output shaft will be spinning the wrong way then.
I only started with this hobby when I was 34, so you are still young. Some of the members here are much older
EBACH
va
oh, ok. never knew. and HA never thought about the output shaft spinning the wrong way. ouch. sprocket is going to have to go on the left side for sure.
EBACH
va
any suggestions for keeping the disc brakes on the right side???
anyone?
smgs92
hydraulic brakes will let you keep them on that side and run the line to the left.
EBACH
va
that works for me.:thumbsup: are these hydraulic brake systems fairly easy to install/maintain?
Relatively easy, the price for a go kart system may hurt a little though...
On a related note, unless you intend to re-engineer the entire kart, I strongly urge you to reconsider moving the brake to the left side given how easy it is compared to the amount of work you'll need to do if the sprocket is on the left
EBACH
va
my sprocket has to be on the left side. im not doing a jackshaft, doesn't look like i could make one work anyways because my axle is not exposed in the middle. all else fails, i'll put a band brake on it i guess. i'm willing to do the hydraulic brake system and anxious to get this kart going, but i do want everything done right.
jamyers
Buffalo Gap, TX
Seems simple to me, sprocket on the left, engine just inboard of that (need a mounting plate of some sort), and brake disc on the right with a hydraulic hose from the master cylinder on the left front. Or did I miss something?
EBACH
va
really wasn't trying to have hydraulic brakes on my kart. but if i have to go that route i will.
dreazoian
Los Angeles
The axle sprocket can be up to 2" smaller than the back wheels.
Here's a quick lesson on gearing:
Low numbers = high ratio = high speed
High numbers = low ratio= low speed
A high ratio will give you high top speed & poor acceleration
A low ratio will give you low top speed & good acceleration
A large clutch sprocket & small axle sprocket = high ratio
A small clutch sprocket & large axle sprocket = low ratio
60:14 = 4.28:1
72:14 = 5.14:1
You want somewhere around 7:1 or 8:1
OMG! I have been confused with the gearing ever since i got a go kart (1 month ago) FINALLY thanks to you i understand it!! Thanks!!!!! :smiley_omg: :thumbsup:
