Sprocket onto axle
tykenfitz
Hey guys I was thinking about doing something with a live axle, but I've never used one b4 so I'm gonna need some help. First of all the axles on NT look like this from the side right?
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_21285_21285
so I would need a hub to put the sprocket onto the axle but the hubs on NT look like the pic above wont I need one that looks like this?
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_35760_35760
Horrible drawings but you get what I mean.
jr dragster T
Cold place
The axle has a keyway (Slot) and the hub has a keyway. Most 1" axles have a 6.35 mm or 1/4" wide keyway cut into them. You buy 1/4 x 1/4" square keystock and insert it into the hub and axle locking them together.
jetlag
Memphis, TN
I'm sorry, I don't quiet understand this.
Does the 1" axle from Northern Tool have a keyway slot across the whole axle or only on the ends?
Where do you get keystock from?
What is stopping it from sliding back and forth on the axle?
If the keyway on the axle is 1/4" deep, and on the hub is 1/4" deep...wouldn't the "keystock" have to be 1/2" x 1/4" to slide in?
pmat
noob
lake wynonah, pa
Yes it does, all the way across.
not too sure about the key stock
set screws on the sprocket holder and brake hold it down
and no idea.
theo
You can get keystock from any hardware store, bearing outlet or tool store.
Most hubs have 2 set screws one holds the hub in place and the other locks in the keystock.
The notch is 1/4 wide and 1/8" high.
theo
