Spider Carts Recluse
cpt.skier
Calgary Alberta
Hey guys. I recently bought plans for Spider Carts Recluse. I'm wondering if there are any modifications I should be planning on making immediately. I have a Honda GX120, but I may need to switch (the engine was previously used on a pump and the pump section has become rust to the shaft). If I cannot use this engine what is a good option?
redsox985
PA
Try to put some penetrating oil on it. It may still be a tapered shaft and thus useless but it is worth a shot. That is a pretty small kart so, depending upon your size, you may want to lengthen it, which will change all the angles and possibly other measurements.
r97
Measure twice cut once
Massachusetts, USA
if it is tapered,
1. if your lucky you may find a tapered clutch that fits it on ebay.
2. get a tapered sprocket or pulley (if one exists) and run that to a js (1 to 1 ratio) with a normal clutch.
3. have a machine shop machine the crank shaft.
4. install a new crank shaft.
5. make an adapter.
TimG
Memphis,TN
The Recluse is small, lengthing the frame is a must unless it's for a small kids. Even then you might want some growing room.
My son and I just finished a recluse, we used a 6.0Hp. robin subaru from the small engine warehouse for $225.00 shipped. Were very happy with the motor and it has plenty of power.
cpt.skier
Calgary Alberta
I'm probably going to grow to about 5 foot 8 inches (wishful thinking). How much should I be lengthening the kart original plans. Maybe five inches?
redsox985
PA
I think he clicked multi quote then went to a different thread and quick posted and it attached those from elsewhere.
