Spark
Dallas1231
When I hold the spark plug wire end and turn the flywheel I get shocked. But I don't have spark on the spark plug. It is a new plug. What most likely is the problem. Could it be the coil not making enough power??
fowler
Bullsbrook West Aus
Ha
Yes you will get booted
I don't recommend it
U have to touch the spark plug to the block to get it to spark
So plug it in then touch the end to the block and pull the cord
If u still have no spark
First check the plug gap and electrode condition
Then ensure the kill switch works and the low oil sensor
Is working
Ensure u have the correct oil level
Then regap the coil
If that still fails then u are up for a new coil
Dallas1231
I have an old Briggs and stratton engine. I don't have any sensors or a kill switch.
fowler
Bullsbrook West Aus
Not always
U can't really measure voltage by how much of a jump u get
U can get a boot but it'll still be too weak to spark
If u have no kill switch how do u stop it
The old earth strap across the plug?
If its on a kart I'd highly rekon end fitting a kill switch
For safety
In that case
How does the plug look
A new plug doesn't always equal a good plug
The gap should be around a mm
And the plug should show no visual damage
And if that doesn't work then it'll be a magneto regap or a new magneto
Throw up some pics of the engine
Even if its just to show off your toy
They may give some hints as to the issue
The magneto gap to magnet should be about as thick as an average business card
( you know the ones the buisnessmen give to people with there name and number)
Let's get down to the nuts and bolts of the propblem and make sure you're not barking up the wrong tree here...
Does the engine run? Have you verified fuel delivery? If you are getting shocked holding the plug, there's probably a 90% chance that you indeed DO have spark, and your engine issue is elsewhere.
Verify spark plug gap at 0.030", a good baseline if you don't know your particular plug gap spec. Pour a teaspoon of fresh fuel into the spark plug hole, screw the plug back in, connect the plug wire, and attempt to start the engine. If it runs for a few seconds or even gives you one or two good pops, your issue is likely fuel delivery/carburetion.
Tell us more about your engine, and the problem. What kind of engine is it? How long have you had it? Has the problem existed as long as you've had it, or is it recent? What happened the last time it ran, and how long ago was that?
