Let's get down to the nuts and bolts of the propblem and make sure you're not barking up the wrong tree here...
Does the engine run? Have you verified fuel delivery? If you are getting shocked holding the plug, there's probably a 90% chance that you indeed DO have spark, and your engine issue is elsewhere.
Verify spark plug gap at 0.030", a good baseline if you don't know your particular plug gap spec. Pour a teaspoon of fresh fuel into the spark plug hole, screw the plug back in, connect the plug wire, and attempt to start the engine. If it runs for a few seconds or even gives you one or two good pops, your issue is likely fuel delivery/carburetion.
Tell us more about your engine, and the problem. What kind of engine is it? How long have you had it? Has the problem existed as long as you've had it, or is it recent? What happened the last time it ran, and how long ago was that?
