some of my welding
robin
in a house
here is a picture of a weld i just made on my gokat the slag did this itself lol
kibble
I banned myself
Soooo... are you trying to show off, or get feedback about what to do better? Cuz I got nothing to say other than it looks great! :roflol:
robin
in a house
well this is some of my better welding i still cant always get a nice bead around tube ive just got a stick welder i have have been welding for little over a year now thanks for your comments
"Looks great, so what rod are you using now?"
just a normal 2.5 dunno what number or anything lol
i still cant get them other rods to weld
oh for any one that was wondering i have a sealy 180 amp arc welder
modelengineer
Lord of the noise
Sydney, Australia
If the weld is good then the slag will come off in large chunks, or one large chunk. If it is really difficult to get off then something is wrong, or the rods just produce weird slag.
That's a great weld.
robin
in a house
im looking for an answer off any of you guys that no your stuff about welding if you read a previous post of mine i could not get some welding electrodes to weld
i have just noticed there is a number on them if it could shed some light on the subject
that are SAF-FRO rods
and on the rod itself it says
SAF DRY 510 7018
modelengineer
Lord of the noise
Sydney, Australia
7018 rods are low hydrogen rods. Before using them you have to bake them in an oven for a while at a specific temperature (found on the web). Then you take them out of the oven and can use them. They are good for 2 hours out of the oven before they become useless again and have to be dried again.
robin
in a house
would you mind telling me what mettles they are used fore
on the packet it says re bake moist electrodes 2 hours at 300 350c
and thanks for replying
Kenny_McCormic
Kartless....
Michigan Troll
7018 is generally used for high strength critical stuff. They have to be dry because the arc will convert any water into hydrogen, ruining the low hydrogen properties of the rod.
robin
in a house
i did not want to start a new thred as i dont thyink its needed
i got some stanless steel i have welded up and exhaust with it but i uses normal steel welding electrodeds think thay were 6014 the welds went the best looking but it quite strong what im asking is will it rust ?
eesakiwi
Yup, Nice weld.
It will have something to do with you using good rods too.
I wouldn't recomend anyone use General purpose rods, get Low Hydrogen rods. Practice & get good at it.
In general purpose welding heating the rods isn't that important.
I know in doing a welding test or critical welds I will use preheated dry rods.
They are normally stored in a old fridge thats got a hot lightbulb or element in it to keep the rods dry. Or straight out of the box.
At home I jst make sure they don't get wet, if they do I will heat them again, but normally don't have too.
Welding stainless with steel rods.
Yeah, the weld may rust.
Depending on the quality of the stainless steel depends on how much they will rust, better quality (non magnetic) = less rust.
Normally its just a surface rust specks.
Thats Ok for home, no need to get special rods etc.
At work, thats a different matter.....
03BLACKGT
I do structual work on barges and although you should bake your rods, its not exactly necessary. Like stated above, as long as ure 7018 rods arent wet, you should be ok. 7018 can take you alot of places if learn to run it right. Lots of practice, lots of patience.
