So why wouldn't this work?
Nick
Hoschton, Ga
This just seems way to simple to be a feasible way of doing things.
I am designing a rat rod similar to some pictures I've seen on here where you use a wheel barrow bucket as the main body of the cart but the biggest issue is that I want it to be front engine and am having trouble finding a way to transmit power to the rear wheels.
The plan I'm considering is turning the engine so that the shaft points towards the front of the car with a CVT set up vertically with a long drive shaft running out of the driven pulley to the back of the cart where it would go into a 90 degree gearbox to drive a chain that would drive the rear axles? This seems to me like it would work as long as the shaft was mounted properly. It would definitely not be a cheap build though...
Hopefully the picture makes my design intent more clear. It is missing the 90 degree gearbox and chain though.
Half-breeder
"Edit" button removed
That just sounds like a setup that could go wrong fast. You will also lose a lot of power at the wheels...
:iagree:
It's proven that 'extensions' of pretty much, ANY kind, rob power... extension cables, socket extensions, even drive shafts...
PLUS... another variable to consider that carts dont accommodate...have you ever wondered about the 'hump' inside the middle of cars/trucks(w/ rear drive) and why they are there?... just something to think about.
Jim-L-L
South Australia
It could work, but yeah it would lose a lot of power and be nightmare to build. What size engine are you going to use ? If it's only small ie. 6 -9 Hp then maybe a honda clone with a built in centrifugal clutch and 2:1 reduction box ? the tail shaft could connect with a universal just like RWD car and that would eliminate the CVT setup, at the rear axle end you would still need a 90' of some kind as well as some more reduction say 3:1
Well right now I remember two front engine karts
IceMan198753s T-Bucket and Bandos Jeep.
Both use vertical shaft engines off a tractor mower;
I think there's a reason for that.
A belt that long is much less hassle than a turning shaft,
so maybe you just want to get the necessary parts off a riding mower yourself to have a "known to be working" set up ;)
rocketkart
florida
i made a mini jeep useing a honda clone 6.5hp engine the engine was in the front of the kart and we mad a drive shaft that went to the Rear End. we used a ridding mower Rear End that we flip't to the side so the drive pully was faceing forward of the kart and we used a steel bar and some universal joints to connect useing the bar a a drive shaft.
fowler
Bullsbrook West Aus
Yea it'll work
I don't see how u will lose power
It's a solid shaft with a few bearings
What u put in u get out
Minus a little friction from the bearings
But f/a in the scheme of things
What will stuff u is if the shaft is out of line
Extreme friction vibration and
And eventually snapped shaft
Anougther issue which I assume is what everyone is calling loss of power is wind up in the shaft
It torque twist
When u gym it the shaft wil want to wind up like a spring as the engine turns but the wheels don't want to
But if u have this then your doomed from the start
Windup should not/ is not allowed to exist in a transmission
It's a anougther issue that will cause failure
If I were u I'd run the TC at the back
Run engine speed down the shaft
Higher speed but far less torque
My biggest concern would be u have a fast spinning shaft running between your legs
My 2 cents:
It's not a horrible or totally daft idea, it will work if it's set up correctly.
IMO, the best/safest ideas came from Jim-L-L (wet clutch redux box) & rocketkart (inverted tractor axle). Combining the two would work but, your biggest problem would be gearing...
rocketkart
florida
that gives me a new idea of makeing a scaled down version of a vw buggy useing a ridding mower transmission facing forward on its side and a engine on top with the pull start out the back of the buggy with a belt drive and a idler pulley to engage & disengage to work as a clutch. this got me thinking.
cool idea..
try to find an older B&S 180° V-engine (or is it indeed a Boxer?? I don't know) anyways,
it looks like a 2cyl boxer, which makes the VW-buggy even better *gg*
Nick
Hoschton, Ga
The vertical shaft engine with a long belt like Sid mentioned was my back up plan and based on what you guys have said I'm thinking the back up plan was probably the better of the two. Thanks guys!
By the way this is my latest "build" that this question was about.
Well, you don't need a suspension of 300mm if you only have 100mm clearance;
the frontwheels look to be too small (caster wheels??)
And the barrow bucket, with it's front wall reattached like this, it will keep you inside;
that is not a good idea in case of an accident; if you roll, you'll snap your neck :eek:
Also, if it's a steel bucket, you will have some sharp edges, and with the snapped neck there's chopped legs... not pretty.
So if you want your kart low, then no suspension, if you want suspension raise it ;)
and make sure the suspension locks befor the chassis hits the ground.
Also keep in mind that the belt will have to run UNDER the bucket and is not pleased if it meets the pavement ;)
fowler
Bullsbrook West Aus
well a normal kart has a space at the back for the engine
so u put the seat where the engine goes and u put the engine where your feet go
it wont need to be that much bigger
Nick
Hoschton, Ga
I was wondering about the leg room myself but hadn't got that far in the design but I'm sure Ill come ulp with something. Hadn't really thought about those safety issues though... The sharp edges are fairly easy to fix and I could probably fix up a seat belt to prevent the next snapping issue as well. As always thanks for the advice! Sadly I don't for see this project getting any kind of work other than SolidWorks done on it for a very very long time. You know the whole in college and no money thing kinda gets in the way of this kind of fun...
fowler
Bullsbrook West Aus
a seat belt is goong in the wrong direction
unless u fit a neck belt out of t=The Onion Movie
but that didnt work too well either
http://www.youtube.com/watch?v=meiuOQHTsNg
the problem with a seat belt is it holds u in the kart
when u have no roll cage u want to be thrown any from the kart so it doesnt land on u
take this for example
u go round a corner way too fast and roll
in a standard kart
u fly out, tumble and roll away
get up missing a bit of skin and worst case broken arm
but if u were strapped in
as the machine flips it would fly for a litle then land on its side or unside down
either way u have the inertia of your own weight plus the weight of the kart useing your head as a landing point
not pretty
ask your self why don't motor bike have seat belts
Jim-L-L
South Australia
in a standard kart
not pretty
:funnypost::funnypost::funnypost::funnypost::funnypost:
Reminds me of years ago when they decided to have aircraft carry infant seat belts for kids to small for their own seat, a design was come up with which is like a figure 8 one loop goes around the kid, the parents lap belt goes through the other loop, the seat belt company asked to manufacture them would only make them if they could put a label on each belt that stated "use may be fatal in accident"
