Nick
This just seems way to simple to be a feasible way of doing things.
I am designing a rat rod similar to some pictures I've seen on here where you use a wheel barrow bucket as the main body of the cart but the biggest issue is that I want it to be front engine and am having trouble finding a way to transmit power to the rear wheels.
The plan I'm considering is turning the engine so that the shaft points towards the front of the car with a CVT set up vertically with a long drive shaft running out of the driven pulley to the back of the cart where it would go into a 90 degree gearbox to drive a chain that would drive the rear axles? This seems to me like it would work as long as the shaft was mounted properly. It would definitely not be a cheap build though...
Hopefully the picture makes my design intent more clear. It is missing the 90 degree gearbox and chain though.
