Small engine shaft
trekklee
Hi i have a small engine and on the shaft there is no hole to put a bolt in to hold my Centrifugal Clutch and i wonder if you can like make one or something..
What is the engine to be more specific. Can the crank accommodate a tapped hole in the shaft?
Yup, folks are correct. Shaft can be drilled and tapped to 5/16UNF24. May not be necessary though if your clutch features setscrews.
