side cover stuck?
r97
Measure twice cut once
Massachusetts, USA
Hello,
I'm in the proses of taking a lawn mower engine apart. all went smooth until i went to remove the side cover. the cover will slide away from the case, down the shaft maybe 1/2", then stop. the shaft was a bit rusty so i gave it a light sanding first. then it still wouldn't budge, so i let it soak in oil over night. still nothing, so i picked up the engine by the side cover, and hit the crank shaft with a rubber mallet, i thin it may have budged a little bit, but not much, and i was hitting the shaft for a very long time.
i'm looking for tips, right now its hanging by the side cover with oil soaking into it, i may go rent a puller tool and try that... whats wrong? am i just being too much of a noob and not releasing something i'm supposed to? or is the crank to rusty, or is the oil seal screwed?
Thanks.
fowler
Bullsbrook West Aus
the crank will need to be perfectly smooth
it hasnt twicsted to one side has it
can u remove the oil seal from the side cover then cut it off
r97
Massachusetts, USA
no noticeable wobble, and it didn't vibrate excessively when it was running.
i can try to remove the seal.
Same thing happened to me. I had to use an angle grinder to get the rust of.
maybe i will use a small grinding stone on the drill if all else fails.
Russ2251
AZUSA:Powered by LAWN-BOY
Seal is not the problem. There must still something interfering with side covers ability to just slide off.
Continue to use emery paper and oil. Please do not grind anything. Surface should be as smooth as glass.
r97
Massachusetts, USA
more light sanding did the trick.
now i went to remove the flywheel, the key is damaged (would explain the kick back problems the previous owner was telling me about). now the fly wheel wont come off, i know its always a bit of a pain, but its not budging (wish i had a puller...). the key is really screwed up and i think its jamming the flywheel a bit.
Russ2251
Don't need a puller.
Give it some whacks on one side of flywheel using a 2x4 and a sledge.
r97
Massachusetts, USA
thanks, but no luck. i hit it many times in several places, pretty hard. had my dad help hold it too so i could get a better swing. the end of the 2x4 is all screwed up because of the fins. i was kinda worried the fins would break, they aren't very thick.
any other suggestions? should i try again until it works? would pics help?
r97
Massachusetts, USA
yes! victory! many thanks russ! i put together a quick spot to screw the engine down to some wood, then i could stand up and focus on swing the hammer and holding the wood just above the flywheel, and it worked.
thanks again! now i know exactly what to do next time.
r97
Massachusetts, USA
i wasn't going to remove the flywheel but then i was told about the kick back so i decided i would investigate the key. i saw it was damaged so i had to remove it, but i had already began to remove the side cover.
at this point i'm just going to completely rebuild the engine, then reassemble, test on lawn mower, then i'm probably going to convert to horizontal. thinking about whipping together one of those "drift trikes" on a low budget just for kicks.
r97
Massachusetts, USA
HEHEHEHE, its a style of electronic music, as my cousin described it "drum, base... and spaceship farts" LOL. i enjoy many kinds of music, rock, metal, glitch, dubstep, jazz, stuff from the 80's, random stuff, etc.
the music i USUALLY (not always) do not like, is country, pop, rap, and classical. especially a lot of the crap they play on the radio, i can't stand the stuff they play at the school dances! :D
heres an example of some "glitch" music,
http://www.youtube.com/watch?v=nxk1BY6wKT0
