BirdFanatic
30+years of siting in the sun dirt dust rain and i got the behemoth snowmobile engine running again .1984 600cc Polaris indy 3 cylinder 2 stroke .Registered in 1984-1985 get this 219 original miles on the engine still on the gauge all i did was clean the carbs put 50/50 anti freeze in the radiator and new line from the bottom of the engine to the over flow cap on the radiator sprayed some lubricant and carb cleaner in each carb and pulled the pull start and it started up .
.Seems i am good with old machinery and things that have not run in ages .What a great sand rail or buggy engine
screw old VW engines with only 32 hp that weigh 4-500 pounds fully assembled (With trans ) .This bad boy has 100 and weighs 150 pounds fully assembled .
As far as all your buddies breaking. VW's.....some folks can break a steel ball bearing with a rubber hammer....
