Shes alive
BirdFanatic
Jonesboro Arkansas
30+years of siting in the sun dirt dust rain and i got the behemoth snowmobile engine running again .1984 600cc Polaris indy 3 cylinder 2 stroke .Registered in 1984-1985 get this 219 original miles on the engine still on the gauge all i did was clean the carbs put 50/50 anti freeze in the radiator and new line from the bottom of the engine to the over flow cap on the radiator sprayed some lubricant and carb cleaner in each carb and pulled the pull start and it started up .:wai: .Seems i am good with old machinery and things that have not run in ages .What a great sand rail or buggy engine :) screw old VW engines with only 32 hp that weigh 4-500 pounds fully assembled (With trans ) .This bad boy has 100 and weighs 150 pounds fully assembled .
rocketkart
florida
you may have way more hp with your 1984 600cc Polaris indy 3 cylinder 2 stroke but i can assure you that a old VW engines with only 32 hp that weigh 4-500 pounds fully assembled will outlast your 1984 600cc Polaris indy 3 cylinder 2 stroke by a lifetime.
BirdFanatic
Jonesboro Arkansas
Maybe then again a well taken care of 2 stroke can last a lifetime to kt-100s and mcculloch last for ever .Oh and lets not talk about the cost your basically paying more for less when you buy a Volkswagen engine .Parts are twice what they should be and they always break i have seen all four of my friends Volkswagen break down constantly fixing them like a old ugo they always break .
rocketkart
florida
2 trokes never last as long as a 4 stroke. i know.... i fix the d*** things all the time.
Connecticut, USA
I think the others point here was that each motor has its ups and downs... No need to say its "better than another motor"
Personally I'm a 2 stroke guy! That doesn't necessarily mean i would pick this motor over a vw though.
lol where do you come up with all this stuff .
Well....I will elaborate....around here....when someone takes a stand....or opines on something....and then changes their stance on the issue....it's called. "Crawfishing".....because....as any good Southerner knows....a crayfish..(or crawdad, or crawfish )...when spooked....moves as quickly as possible in reverse ...so a person who changes their position on a matter....for no apparent reason...(except possibly to save face when faced with overwhelming opposing opinions).....is "backing up"....ergo...."crawfishing".....
Louisiana exports tons of tons of crawfish in the Spring...."Crawfish season".....
Anything else I need to explain?????
EDIT: Just to clarify: Your last post seems to be pro Volkswagen, while earlier ones were strongly anti-Volkswagen.....
BirdFanatic
Jonesboro Arkansas
Lol that is a good way to look at it.I change my opinion because i have to look at it in different ways and i cant be stubborn .
I was just wondering how a motor could be street legal? Is it not the vehicle that the engine is in that has to be street legal. I know the engine might have to adhere to some HP specifications, but in my mind it is the vehicle it is in and not the engine that makes it street legal
BirdFanatic
Jonesboro Arkansas
Engines that are two stroke are not street legal because the EPA board says they are stinky and emit to much pollutants .
