Sequoia Electrathon Racer
Hey T,
Yup, the (6) outer bolts, nuts & washers are just to hold the rim together
...& the (4) inner holes are for mounting the rim to the hub
The dimple things are for the (2) halves to "fit" together (as in "spoonin'") ;)
Also, it seems like I sent ya (2) inner halves
...'cause I have (2) outer halves (notice the double valve stem holes?)
Ok, got it,! I suspected that "might" be the case. After exploring all the other possibilities.
So, i'll procede with the 4 bolt. So, the drawing ya sent is for V1.0?
I can make mistakes easy enuff as is without added confusion!
you tring to trip me up?:rolleyes:
so ya good with 5/16 x 24 threads for yer bolts/studs?
IIRC all of the front hub specs are the same as the front hubs for Sequoia
...it's just this version (for Tsunami) has different wheel & rotor flanges
Yup, 5/16 x 24 threads should be fine for the bolts/studs :thumbsup:
There's the problem, l can't remember what l did last week.
When one part is done, l have to delete the files. Too many numbers & dimensions competing for limited space in my head. The limited space is actually diminishing space, the bad sectors keep turning up.
Ok Kevin, you ready for plan revision # F? Or is it E, l don't remember.
Here it is, whatever revision...
We need 4 inch flanges for the wheel. Any bigger and the wheel bolts are going to interfere. I have 6 inch hex blanks. As much fun as it might be, it's just too much work to make 4 inch flanges out of 6 inch material. Even the slaves in the dungeon threatened to riot...
So, remember that piece of 3/16 that was the brake flange material?
l have a 4 inch hole saw.
Well, same process for these.
Stay Tuned, more tomorrow.
The "new" brake rotors are purdy thin and are creating a little problem. They flex just by tightening the 6 bolts. Runout as it sits now is about a variable .010 -.020. adjustable by torkin the bolts. So do you have an indicator? I think yer gonna need to tork the bolts at final inatallation, to minimize runout. I believe the problem runout will create is brake drag.
https://youtube.com/shorts/8RCyiOg91hw
Hey T,
Yup, shouldn't be a problem :cheers2:
Chinesium parts are almost always "warped" a bit (some way or another) :mad2:
...but, we may be able to use that "adjustability" (to our advantage) to true 'em up :thumbsup:
