Send pictures of your choppers and minibikes
Here is my take on the Tom Thumb minibike plans on this forum. I really didn't NEED a minibike but I wanted to learn how to TIG weld (still a lot of learning to do....). There were some modifications of the plans; the handlebars are taller, there are footpegs and footpads because there at nearly 6 feet and 60+ years of age this was the only way I could ride it. It's also wider because I am (somewhat) wider than the skinny kid who originally made one. There is a brake; the hub brake/sprocket adapters are homemade, the wheels/tires are Harbor Freight, the engine is a 47/49CC Chinese engine with a transmission so no jackshaft was needed. The gas tank is PVC fittings and the seat is homemade and was then upholstered by an auto trim shop. I welded on a kickstand. I really tried to DIY everything because just getting a kit or buying off the shelf and screwing everything together is just not very satisfying.
The tools I used were fairly crude; MIG/TIG welders, a bandsaw, angle grinders, a chop saw, tube notcher, and the low-end HF pipe bender (that I bought used cheap). It was impossible for me to go much more than 90 degrees so this was done by cutting and welding the curves. This was difficult and tedious. The bends on the back were just BARELY done with sand and BB fill and constant repositioning. The cables were off the shelf but I had to cut them and remake the throttle cable end. I had a waste factor of about 2x on the pipe.
A lot of this was "barely"; the front tire barely fits; I can barely ride it; the engine barely fits; I barely bent the pipe. The muffler barely fits. in short, I got somewhat lucky.
I originally had a 72 tooth gear on the back and it didn't go very fast but the torque was crazy.
I look fairly silly riding it but all in all it was a satisfying project. I hadn't actually BEEN on a minibike for about 45 years until I rode this.
Awesome bike!!! And thanks for the build info. I don't think i have ever seen someone try those plans, finish, and actually post to the forum about it.
If you have any build pics, why dont you start your own thread in the Projects section and show us the process you went through :thumbsup:
Noseoil
Terrible Tim
Tucson
I built it from the ground up. It's 1" DOM tubing, a bit heavy, but strong like buffalo.
SuperBlazer
Stupid is as stupid does.
California
Some members of my Pack of mini bikes. 1969 SuperBlazer the Alpha.
RKMLL
New member here, hello everyone. He's a couple of my minis. Love my bajas. First one has a built 212 with all the goodies. Middle one is my street mini with a predator 301, third is a razor mx650 I converted over to a 5hp engine. Last one is my dad's (arco? ) old mini I'm working on.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Dude the last one is an arco?! I have the same bike been trying to figure out what brand it is!
numscul
Eastbay Area California
Hey guys I'm just starting this because id like to see what you've made and give people the opportunity to flaunt their work a bit. I'm in the process of building my first as well and could use some inspiration. Cant wait to see what you guys have!
This is a mini bike i have been working on for a long time
The frame is a HOG TY that i modified to accept the engine with shock absorbing engine mounts
It has a 10hp Diesel engine i found on Craigslist and got it for $300
The clutch is a NORAM that cost about same price as the engine due to the fact it's a low RPM high torque engine
The seat is from a Harley Davidson and the clutch cover is from a rototiller that i took down to bare metal and polished
Over all this not so mini bike is able to reach freeway speeds and still climb a steep hill with little to no effort
Ivansanloz
Gramo por aceptarme Ali muestro mi trabajo
Took a year to custom build this from scratch. Too terrifying to ride, 12+ horses on an asymmetrical CVT.
