Is the only difference between a screw and a bolt is that a bolt is used with a nut? I never know what to call these things.
A screw engages with wither the material being fastened, or the material being fastened to, ie wood, sheet metal, a pre-threaded hole, etc.
A bolt engages with a nut on the opposite side of the material.
That's all.
A single fastener can be a screw or a bolt depending on how it is installed. A 3/4"-10 fastener for example is a hex cap screw if it's threaded into a tapped hole, and a hex bolt if installed with a nut on the back.
Easy way to remember:
If you have to screw it in, it's a screw.
No, because the fastener is not making the thread. The thread is machined, and is therefore, in principle, a nut. Like you.
If the argument is that the fastener being used, for example, on your side cover is a screw, because there is no bolt present, then if you take that exact same "screw" and fasten it elsewhere using a nut, it has now transmorgiphied into a bolt?
That's NOT what I learned of being the difference..
SCREWS are ALL thread (even machine screws)
BOLTS however have an unthreaded part
That's what I've been told... but I guess that's the old
"while there are flathead screws, there is no such thing as a flathead screwdriver!"
dilemma.
As long as people know what you are talking about, you can call them anything you want;
(pastell for example is STRICTLY blue color! pastell colors however come in many different dull shades; they're just named incorrectly still everybody knows what's meant by that)
LOL.. Yepp...
and then you stumble across a lag bolt and all goes haywire
That's technically a lag screw, though it is commonly referred to as a lag bolt.
Look them up from any major fastener and hardware supplier like Grainger, Fastenal, etc (not home Depot)... They will be categorized as "hex head lag screws"
