Score!!!!
1992suburban
I wanna go FAST!!
Sanford, NC
lemme help as if I were building
11 inch tire ( basic cart tire)
I would fab up a 1:1 ratio.. 14 tooth is on motor so I would put 14 tooth on axle..
you will have to prolly weld the sprocket to a hub.. since thats a SMALL sprocket
3.722 is the primary drive (gear reduction)
1.19 is 3rd gear
14 drive
14 driven
8000 rpms would net a tope speed of 59mph
1st gear would tach out at 20mph
now this WOULD NOTWORK off road
if you wanted a top speed of 45 the gear calc would be 20tooth on axle
keep in mind this is in THEORY
1992suburban
I wanna go FAST!!
Sanford, NC
there are some SHARP folks on here they should have some input as well..
this is all theoretical so.... and I am just GUESSIN it will work
1:1 ratio because the gear reduction built in to gear box... then the 3 speed should work out
kazkepox
Pro- one idea to the next
Panama City, Florida
i know Im putting pressure by asking you all the questions, but you have been the MOST help, unlike some dream crushers *cough*Kaptain Krunch*cough*. you my freind have helped me the most in almost all of my post, so here is a cookie.
kazkepox
there ar eplenty of sprockets on there that arent keyed and come with set screw openings...sounds like something I can use, i just need to know what # chain I am using...
