11 inch tire ( basic cart tire)
I would fab up a 1:1 ratio.. 14 tooth is on motor so I would put 14 tooth on axle..
you will have to prolly weld the sprocket to a hub.. since thats a SMALL sprocket
3.722 is the primary drive (gear reduction)
1.19 is 3rd gear
14 drive
14 driven
8000 rpms would net a tope speed of 59mph
1st gear would tach out at 20mph
now this WOULD NOTWORK off road
if you wanted a top speed of 45 the gear calc would be 20tooth on axle
there are some SHARP folks on here they should have some input as well..
this is all theoretical so.... and I am just GUESSIN it will work
1:1 ratio because the gear reduction built in to gear box... then the 3 speed should work out
i know Im putting pressure by asking you all the questions, but you have been the MOST help, unlike some dream crushers *cough*Kaptain Krunch*cough*. you my freind have helped me the most in almost all of my post, so here is a cookie.
there ar eplenty of sprockets on there that arent keyed and come with set screw openings...sounds like something I can use, i just need to know what # chain I am using...
