Haha bad time to seize...
I went to change the gearbox oil, took the plug off to drain out the old stuff, and guess what came out? water...not much but enough to worry about. I took the sidecover off, managed to break the gasket but only in one place. The idler, crank, and clutch gears dont seem to rusted, but the clutch is stuck. The bottom end seems fine, luckily its a 2 stroke so the crankcase and gearbox isnt connected.
EDIT:
Alright, i got the clutch apart, unstuck it, but it still isnt working so i guess i gotta take the other side off and see whats happening with the actuator thing over there. I managed to lose one of the little bars that holds the spring in place already, hopefully i can find a replacement tomorrow.
The crank spins freely, but the bearings sound worn out, hopefully its just dry and needs some oil.
