Scooter Project Help
I have another question.
Will this Brake band actually work to stop the Kart with it on the clutch bell?
I guess in theory it would work. But too much heat would be generated and negatively effect the clutch's life span.
Particulary on this build due to the High Gear ration being possibly attempted.
It will work, but if you throw a chain or the chain breaks.....then you have no brakes
cchurchill
Albany, IL
Can you mount a jack shaft directly above the axle?
Also, have you seen The one Colin Furze built?
http://youtu.be/w7gWMgN1NGM
I am going to try the new setup first before I try and put a jackshaft on.
That is where I got my inspiration!! LOL. I went with a predator because I had a spare one laying around so I wanted to use it for something.
---------- Post added at 08:19 AM ---------- Previous post was at 08:18 AM ----------
Yes, if there is a failure I will have no brakes. I am not to worried, when people see a granny scooter going faster than it should they will move out of the way. LOL
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
People will move, Cars, walls and Trees will not. LOL
Please figure in some better brakes.
I'm not dissing you, I like this build, but be safe or be dead, You know
