Savable?
EagleTalons
Master JB Welder
Forsyth, Montana
Well, I'd better start at the beginning. I reused the old piston and rings. They were marked 6...or 9. It was running fine until I noticed that the side cover gasket was leaking. So, I took off the engine and got the cover off. The gasket hadn't sealed. I decided that since I was in here, I was going to fix my valve problem too. So I took the head off and boom. A ton of oil was in there... I frown. This is my first engine build... So I take off the con rod. pull out the piston and to my horror...
Is this savable on a Kool bore?
oscaryu1
Put the rings upside down?
If you can feel it with your fingernails, ehh...
But it doesn't look too bad. Hone it out .010 or so. Heck, it could've worn down that much being a Kool Bore.
Now go and find a chromed Raptor or 5HP piston .010 oversize, and .010 oversize rings.
IIRC, they make oversize pistons/rings up to .020/.025.
jr dragster T
Cold place
Looks just like my briggs 3.5 lawnmower engine. And theres always a puddle of oil sitting in the bottom of the bore. I dont think I would want to hone out 0.10" How would you be certain the bore is straight?
freakboy
the names 'mater
hick town
Cool bores suck they get screewed up easy. Just run it till it goes boom and see what goes first rod or flywheel.
EagleTalons
Master JB Welder
Forsyth, Montana
It has a raptor rod in it and its not revving too high because I have 16" tires with TAV and 60 sprocket. I could only go about 40 mph on my Mini. This was on gravel, bumps and turns.
Do Intek's have steel bores?
jr dragster T
Cold place
The Intek should have a steel sleeve. Our Intek 9.5 snow blower has a cast iron bore. This thing will blow any snow or slush and the amount of torque and grunt is just very impressive. Also I've never seen the amount of quality in its valvetrain before.
EagleTalons
Master JB Welder
Forsyth, Montana
This Intek that I have is a 5.5hp, the exhaust was broke on one bolt and the pipe danced on the head until it cracked a chunk of head out.
I'm wonder how am I going to fit a TAV on it?
