So I recently acquired a Rupp wide hoop kart. I’m in the process of tearing it down so I can do a complete restore but I’m having trouble removing the brake. Is there a secret to this? What do I have to do to get it off the sxle? Thanks in advance!
You need to remove the circled allen-head set screw to remove the brake assembly. As well as any others you might find.
And PB Blaster penetrant helps.
JT I already did that, just stuck it back in there so I wouldn’t lose it. And I want it to go the other direction correct? Off the axle not on, towards the threaded part? Unless I’m missing something you are saying.
Look for a couple of threaded holes in the bushing. Then clean them, a bottom tap would be helpful.
Thread in a couple of bolts and alternate tightening until things separate.
You have a couple of studs in the pic, I'm not sure what's going on there.
