Ive been wanting to do some other projects as of late with some wood I stashed away awhile ago...
At my previous job, we used to get alot of these aluminum grating in big bundles. After we break open a bundle they contain 12 pieces of dunage..
Typically they were these rough cut 2x4, 3' long of oak...Fricken amazing wood...
Most of them were straight grained, minimal knots or none.
Ive been wanting to do some easy projects, but I have no planer... Im not really keen on getting a hand plane and chunking away at the board to get it smooth... Mainly Im looking at getting a surface flat and good enough to glue together... with minimal refinishing to get there..
Ive been looking up on a way to do so, and found out on a router plane...
Guys have been using this method for milling large pieces to make tables or the like from cut trunks for live edge ect....
I have no table saw, but hand tools, compound miter saw, router and a few others...
So this is what I came up with....
I made this to accommodate the 2x4 wide side to mill flat...
I roughly find what is the flattest side, that side down, Wedge in place, Touch the end with bit, back off and set for a shade down in height.
Test a short distance as to the adequacy of the depth of cut. Adjust if necessary....
Carry on milling. I used a 50% overlap on each cut, with a smooth even back forth stroke.
Took me almost the day to build the sled/jig and mill 2 pieces before I had to shut down....
Built all out of scraps I found at the bin of the wood lot I go to... guy I know said take all I want...
After milling, there is slight mill marks, but a light sand or a couple of passes with a hand plane... much better to glue 2 pieces together...
Im thinking to build some wood working mallets for the start...
