I'm a student and relatively new to kart engines but eager to learn.
I've just bought a 13.5hp Robin Suburu engine from ebay and am planning on fitting it to a Manco off road kart chassis.
My main issue is the unusual shaped crankshaft, it has a 1" diameter section that is 1" long before tapering off. It also has a larger diameter section adjacent to the engine which I thought i could possibly machine down to 1". ( I have included a photo, apologies for the poor quality but had to take it on my webcam) It also does not have a keyway. Having looked through the forum it seems using a dremel to cut one seems to be a popular solution.
What is the minimum length of useable 1" crankshaft to fit a centrifugal clutch to?
Also would a heavy duty clutch connected in direct drive be a reasonable alternative to a torque converter as being a student cost is a limiting factor. I still have a torque converter from an old 5hp engine but being 3/4" and for the lower hp I presume the driver would not be suitable?
I am in the UK and have been browsing the web and can't seem to find many 1" clutches in the UK?
Any suggestions would be really appreciated!
