Robin 13.5hp 1" clutch choice
tttooommm
I'm a student and relatively new to kart engines but eager to learn.
I've just bought a 13.5hp Robin Suburu engine from ebay and am planning on fitting it to a Manco off road kart chassis.
My main issue is the unusual shaped crankshaft, it has a 1" diameter section that is 1" long before tapering off. It also has a larger diameter section adjacent to the engine which I thought i could possibly machine down to 1". ( I have included a photo, apologies for the poor quality but had to take it on my webcam) It also does not have a keyway. Having looked through the forum it seems using a dremel to cut one seems to be a popular solution.
What is the minimum length of useable 1" crankshaft to fit a centrifugal clutch to?
Also would a heavy duty clutch connected in direct drive be a reasonable alternative to a torque converter as being a student cost is a limiting factor. I still have a torque converter from an old 5hp engine but being 3/4" and for the lower hp I presume the driver would not be suitable?
I am in the UK and have been browsing the web and can't seem to find many 1" clutches in the UK?
Any suggestions would be really appreciated!
r_chez_08
Should be in the shop...
Cornwall, UK
Is the 1" bit the bit nearest the engine or the bit aftter tge step-down?
Do you have access to a lathe and/or a mill.
Rob
tttooommm
The 1" bit is the bit after the step down. Sorry I wan't very clear in my description.
tttooommm
And I don't have easy access to a lathe/mill. There is a possibility I could use the uni one but I'm not sure. Do you think that would be the best course of action?
All my 1" bore clutches require 2 full inches of output shaft length.
I posted some solutions in another similar thread just this morning, they might help you out too.
Click here for my info:--> http://www.diygokarts.com/vb/showthread.php?t=10924
In the UK, you would have much better luck finding a 25mm. bore clutch.
Post how tall your Dingo back tires are, you might need a jackshaft to properly gear it when using a centrifugal clutch. Count and post how many teeth are on your axle sprocket too.
It might also help if you post pics of the back of your kart showing the engine/axle areas too.
r_chez_08
Cornwall, UK
IMO that would be the best idea. Lathe the bit over 1" down to 1" and then you would have about 2" usable shaft, no?
When my brother wanted to use the lathe and mills at his uni (bath) he did a little course. I dunno if your uni offers the same thing.
Rob
tttooommm
Thanks for your replies!
I think taking the wider section down to 1" in order to get 2"s of useable shaft sounds like the best idea. Hopefully I'll be able to do it at Uni but if not I spoke to a local engineering firm who said they would be able to do it for £65 to £100. So fingers crossed for the free uni option!
It's a really nice engine, just been completely rebuilt and starts first pull every time so I'm pretty determined to get it fitted to my kart.
The axel sprocket on the kart has 60 teeth and the wheels are 15" high (approx).
Have you got any advice on taking the engine apart to get the crankshaft out? I have been told it is useful to out the bolts in labelled clear sandwhich bags to make it easier to put everything back together.
I've included a couple of photos of the back end of the kart.
Thanks!
r_chez_08
Cornwall, UK
Take pics as you go, so you know how everything goes. Dont drop/ hammer the flywheel, instead undo the nut until it protects the end of the crankshaft and hit it. This should loosen the flywheel.
Also see if you can find the torque values for the nuts/ bolts you are going to remove.
Rob
