RM125 Shifter Kart Build! (Video Rebuild)
Olyptorius
Canada, Quebec
Gaskets came in for the top end on the rm125. Gonna rebuild that and start it this weekend to make sure everything is running good!
Also for the vaccum valve, would i be able to drill into the rubber boot (as mine is rubber and not metal) and somehow use sealant around the valve or am i better off drilling it into my case? If that's the case, i will be drilling the hole before rebuilding the top end.
walker187
northern maine
When you take off the top end, drill the hole so you have less of a chance getting metal shavings in the bottom end.
walker187
northern maine
I'm not to sure where i should drill the hole in my case though?
The picture shows where most people put their pulse inlet. Like right at the reeds, but not past them. The suction from the engine will bring the fuel from the tank.
Olyptorius
Canada, Quebec
Hey guys so finally got a big fat paycheck. Now comes to ordering the parts tonight! Though it is difficult to find parts for my kart... Anyone know a kart that is similar to MBA's? I need a gas tank and other things that come in various shapes and sizes so i'm a little clueless on which one to buy...
Olyptorius
Canada, Quebec
Here is a list.
- steering hub
- steering wheel
- clutch lever
- sprocket hub (with sprocket)
- front sprocket (idk if 428 cr125 sprockets would fit on my rm125?)
- 3 axle bearings (40mm)
- tie rod (255mm) (10in)
- two male threaded eyes for the tie rod
- burris clamps (for mount)
- 428 chain
Rest would be misc, cables, hoses, small things i can acquire easily.
Olyptorius
Canada, Quebec
Hey guys long time no see! Sorry I've been quite busy with work and snowboarding this season... But good news, spring is near and parts are ordered! So i will be posting an update video soon on the shifter kart rebuild.
Ted Hamilton
Vintage Kart Afficionado
King, NC
Je pense que c'est incroyable! You got the deal of the century with that chassis... I'd have paid triple that... I'm looking for one at the moment. Anyhow, good vids, and good luck with the build. Sharkshifter's a good source, as is seventh-gear . There's some good Canadian kart shops near Ontario too, so that may save you some post. Cheers and bonne chance,
~Ted
Olyptorius
Canada, Quebec
~Ted
Why thank you, seems like i did get a good deal after all! I was pretty lucky finding this one on kijiji for so cheap. Thanks for the links, I purchased a bunch of items off http://www.kartsandparts.ca/store/home.php
Very reliable dealer and answered many of my questions i asked regarding about my kart.
Thanks again, hope you find a kart soon!
