Reviving the Doodle Bug :devil2:
2SlickNick
American Minibikes @ FB
Mesa, AZ.
Springer Seat
A couple pics of how I am mounting the springer seat.
I will trim off access material later.
It looks like a nice fit, I can wait to sit my azz on it:cool:
Edit: just sat on it:wai: Springs are a little stiff, but I think once they break in it will get better. Does still feel better than stock.
2SlickNick
Mesa, AZ.
Gas Tank Location
:idea2:I think the best spot for the gas tank will be under the seat.
Not sure when I will start that, but that is where it will go.
2SlickNick
Mesa, AZ.
Thanks Eric.
I was going to sell it and buy a new one, but I figured - what the hay... I'll just keep improving it.
2SlickNick
Mesa, AZ.
Working on making a cradle for the stock DB tank
2SlickNick
Mesa, AZ.
The space is tight and I want to be able to swap out tanks if needed. To allow me to do that I will put the cradle on a hinge system. That way once I bolt the tank to the cradle, I can then fold the tank in place under the seat and bolt it and secure it to the frame.
I would only use the hinge system to swap out tanks. I would still fill the tank by lifting the seat.
2SlickNick
Mesa, AZ.
Well my always changing mind, did it again:eek: I decided to not put the tank under the seat. The crappy gas tank should not be a permanent fixture to this project.:2guns:
I decided to keep going with the tank cradle and just adapt it to use with any HF 212 engine. So here is what I came up with...
I used a 1.25" angled steel, drilled to holes 4" apart, cut to make a bend tabs out, and just weld that to the tank cradle.
It leaves plenty of room to keep fuel lines off hot engine and for a gravity flowing fuel. Once clean and tighten it down it should look pretty nice.
2SlickNick
Mesa, AZ.
Shocks arrived in the mail today :)
I ended up cutting 3" inches off the DB forks and 7" off the new shocks.
DB tube is 7/8" OD and the shocks are 7/8" ID. I just used a flap disc to smooth the DB forks and slid the shocks on.
I did some of my worse welds ever, got mad and laid crappy welds on crappy welds. I think the wire feeder was jamming...
One day I will get a nice gas mig.
Needless to say I spent alot of time using the flap disc and still need make it looks a little better. Also I did not notice the handle bars were just a little out of plumb. Next time I will check before I weld. I will take a BFH or press and bend those straight.
Even though I haven't driven with the shocks one - I can tell they are going to help out tremendously with the ride. I can bottom them out with all my body wait and pushing down on them. Not too stiff and not too soft. There are about 3-4" absorption.
kevbo22
Colorado
Nice, came out pretty good :thumbsup: Im still debating if I want to go this route. But those are quality units and you would recommend them now that you have them?
2SlickNick
Mesa, AZ.
Thanks. In a few months:auto:
I still need new hydraulic brakes $50( I put the old ones on my daughter's mini), sprocket $39 ( AGK is the only one who sells a #35 to fit this X7 pocket bike rim), disc brake $7 ( the 6 bolt pattern is the same as a mountain bike), rear tire $30, and some hardware.
2SlickNick
Mesa, AZ.
Well I went ahead and taped up the shiny parts and primed the forks. That way I don't have to worry about rust or anything over the winter. When the weather gets warmer I will paint everything. Until then I will prime and wet sand as needed.
2SlickNick
Mesa, AZ.
I have been pretty busy and haven't had any time to work on the Baja Doodle Devil. But I did order some parts to get the pocket bike rear wheel going. I ordered a 130/50-8 street tire not pictured and i ordered 8t and 9t JS sprockets. I will use 9t for solo riding and 8t for pulling sidecar.
I also converted from #35 chain to #420.
All I have left to do is prep, prime and paint frame. Then add hydraulic shocks. And it should be good to go...
2SlickNick
Mesa, AZ.
Getting closer
Primed and ready for paint ( maybe over the weekend, since it should be 54*F ). Some parts arrived and I sure do like the gold chain:cool:
Just waiting on JS sprocket and tire now.
I still need a rear hydraulic brake and see if I can add front brake.
